ISDN Setup
Jun 25th, 2008
I'm setting up a new ISDN link. The link thous the NT Box shows the line as active does not come up. I have checked with local telco and they've confirmed the line as being OK. The show isdn status output is as follow:
003R#show isdn status
ISDN BRI3/1 interface
dsl 25, interface ISDN Switchtype = basic-net3
Layer 1 Status:
DEACTIVATED
Layer 2 Status:
Layer 2 NOT Activated
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 25 CCBs = 0
The Free Channel Mask: 0x80000003
Number of L2 Discards = 0, L2 Session ID = 44
A sample debug output is as follows:
Mar 11 09:36:58.602 UTC: ISDN BR3/1: Outgoing call id = 0x8025, dsl 25
Mar 11 09:36:58.606 UTC: ISDN BR3/1: Event: Call to 27118835714 at 64 Kb/s
Mar 11 09:36:58.606 UTC: ISDN BR3/1: process_bri_call(): call id 0x8025, called_number 27118835714, speed 64, call ty
e DATA
Mar 11 09:36:58.606 UTC: CCBRI_Go Fr Host InPkgInfo (Len=26) :
Mar 11 09:36:58.606 UTC: 1 19 1 80 25 0 4 2 88 90 18 1 83 2C B 32 37 31 31 38 38 33 35 37 31 34
Mar 11 09:36:58.606 UTC: CC_CHAN_GetIdleChanbri: dsl 25
Mar 11 09:36:58.606 UTC: Found idle channel B1
Mar 11 09:36:58.614 UTC: ISDN BR3/1: Activating
Mar 11 09:36:58.614 UTC: ISDN BR3/1 EVENT: isdn_sw_cstate: State = 4, Old State = 4.
Mar 11 09:37:00.614 UTC: ISDN BR3/1: Could not bring up interface
Mar 11 09:37:00.614 UTC: ISDN BR3/1: Shutting down ISDN Layer 3
Mar 11 09:37:00.614 UTC: ISDN BR3/1: LIF_EVENT: ces/callid 1/0x8025 HOST_DISCONNECT_ACK
Mar 11 09:37:00.618 UTC: ISDN BR3/1: Error: Unfound B-channel on Disconnect_Ack - callid 0x8025
Mar 11 09:37:00.618 UTC: ISDN BR3/1: Activating .
Mar 11 09:37:02.602 UTC: ISDN BR3/1: Outgoing call id = 0x8026, dsl 25
Mar 11 09:37:02.602 UTC: ISDN BR3/1: Event: Call to 27118835714 at 64 Kb/s
Mar 11 09:37:02.602 UTC: ISDN BR3/1: process_bri_call(): call id 0x8026, called_number 27118835714, speed 64, call ty
The link does not come up in all the layers. The NT box has been tested with a different working ISDN line and found to be OK. I will appreciate anyone who can assist pick out whta the issue could be. The configuration of the Bri3/1 is follows:
interface BRI3/1
ip address 192.168.1.13 255.255.255.0
no ip address
encapsulation ppp
no ip split-horizon
no ip mroute-cache
dialer wait-for-carrier-time 80
dialer map ip 192.168.1.12 name BRANCH_RTR broadcast 27118835714
dialer hold-queue 20
dialer-group 1
isdn switch-type basic-net3
isdn tei-negotiation first-call
no cdp enable
ppp authentication chap
Thanks you
rajput_p Wed, 06/25/2008 - 09:00
Hi nickolas
first of pls check your router BRI card support the ISDN, Pls share the sh diag & sh ver report so that further can be check.
Pawan Rajput
njorosam Wed, 06/25/2008 - 21:11
This is Sammy on behalf of Nicholas: The router has been used before to originate ISDN calls. Here's sh ver & sh diag:
003R#show ver
IOS (tm) 3600 Software (C3640-I-M), Version 12.2(7b), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Mon 04-Mar-02 20:23 by pwade
Image text-base: 0x600089A8, data-base: 0x60A6A000
ROM: System Bootstrap, Version 11.1(20)AA2, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
SCKE003R uptime is 1 week, 3 days, 22 hours, 23 minutes
System image file is "flash:c3640-i-mz.122-7b.bin"
cisco 3640 (R4700) processor (revision 0x00) with 45056K/4096K bytes of memory.
Processor board ID 27583135
R4700 CPU at 100Mhz, Implementation 33, Rev 1.0
Bridging software.
X.25 software, Version 3.0.0.
Basic Rate ISDN software, Version 1.1.
2 FastEthernet/IEEE 802.3 interface(s)
8 ISDN Basic Rate interface(s)
64 terminal line(s)
DRAM configuration is 64 bits wide with parity disabled.
125K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
003R#show diag
Slot 1:
Async Port adapter, 32 ports
Port adapter is analyzed
Port adapter insertion time unknown
EEPROM contents at hardware discovery:
Hardware revision 0.1 Board revision H0
Serial number 28181831 Part number 800-02245-06
Test history 0x0 RMA number 00-00-00
EEPROM format version 1
EEPROM contents (hex):
0x20: 01 63 00 01 01 AE 05 47 50 08 C5 06 00 00 00 00
0x30: 88 00 00 00 02 05 07 00 FF FF FF FF FF FF FF FF
Slot 2:
Serial number 28182024 Part number 800-02245-06
0x20: 01 63 00 01 01 AE 06 08 50 08 C5 06 00 00 00 00
Slot 3:
BRI (S/T) Port adapter, 8 ports
Hardware revision 1.0 Board revision E0
Serial number 28385664 Part number 800-01237-03
0x20: 01 21 01 00 01 B1 21 80 50 04 D5 03 00 00 00 00
0x30: 70 00 00 00 02 05 30 17 FF FF FF FF FF FF FF FF
smothuku Wed, 06/25/2008 - 21:26
Hi ,
Check the volatage of the line using multimeter.
Place the multimeter points on Pin 4 and 5 and check whether u r getting a voltage between 96 to 104V on the isdn line.
If u r not getting the voltage then check with telco.
Tks,
satish
