Contact Center Express CAD problem
Jun 25th, 2008
I have strange problem with Cisco CAD. I have a Cisco Contact Center Express solution based on Enhanced CCX 5.0 SR1 build 053 and CCM 6.0. After I installed the Cisco Desktop Supervisor and Client I find that I can not log into CCX system and when I check the Event Viewer I get the following error messages. Also, in the "Control Center" with "PARTIAL_SERVICE" state the "Enterprise Server Data Subsystem" service is in "OUT_OF_SERVICE".
Can tell what is the solution to solve this problem (without reinstalling)?
Thank you,
Dan
Event Type: Information
Event Source: Cisco Desktop Sync Service
Event Category None
Event ID: 2
Date: 6/25/2008
Time: 7:07:45 PM
User: N/A
Computer: CISCOCCX
Description:
The description for Event ID ( 2 ) in Source ( Cisco Desktop Sync Service ) cannot be found. The local computer may not have the necessary registry information or message DLL files to display messages from a remote computer. You may be able to use the /AUXSOURCE= flag to retrieve this description; see Help and Support for details. The following information is part of the event: LRM_1000 Failed to connect to ldap.
Event Source: Cisco Desktop Licensing and Resource Manager Service
Event Category: None
Event ID: 2
Date: 6/25/2008
Time: 7:31:42 PM
User: N/A
Computer: CISCOCCX
Description:
The description for Event ID ( 2 ) in Source ( Cisco Desktop Licensing and Resource Manager Service ) cannot be found. The local computer may not have the necessary registry information or message DLL files to display messages from a remote computer. You may be able to use the /AUXSOURCE= flag to retrieve this description; see Help and Support for details. The following information is part of the event: LC0003 Currently in recovery.
Event ID: 2
Date: 6/25/2008
Time: 7:54:44 PM
User: N/A
Computer: CISCOCCX
Description:
The description for Event ID ( 2 ) in Source ( Cisco Desktop Sync Service ) cannot be found. The local computer may not have the necessary registry information or message DLL files to display messages from a remote computer. You may be able to use the /AUXSOURCE= flag to retrieve this description; see Help and Support for details. The following information is part of the event: LC0012 Failed to bind to LDAP server on <192.168.200.7>: <-1> <Can't contact LDAP server>
Anonymous (not verified) Tue, 07/01/2008 - 12:28
Make sure that the LDAP Monitor service and LDAP are running.
ON the client PC, make sure that the Site Setup registry entries are correct. The most common errors are in the LDAP Host 1/LDAP Host 2, LDAP Port 1/LDAP Port 2, LDAP Bind DN, or LDAP Pwd values.
Check that the LDAP Root registry key is valid.
Check that you can ping the LDAP PC from the client
http://www.cisco.com/en/US/products/sw/custcosw/ps1846/products_tech_note09186a0080893b64.shtml
http://www.cisco.com/en/US/docs/voice_ip_comm/cust_contact/contact_center/crs/express_6_0/reference/guide/cad_ecd.pdf
Reboot the LDAP server which in this case resided on the CAD stand alone server.
