Attendant Console Configuration
Jun 25th, 2008
We are attempting to configure Attendant Console to accept more than the default number of 4 incomming calls. In the process I noticed a Pilot Point has never been configured, or an ac user. The Administrative Guide indicates you need to configure both of these, although the Attendant Console seems to be working. Does this sound like a misconfigured AC?
The receptionist has her personal line on the first button of a 7970. There are 3 main lines (for 3 differnt organizations) on buttons 6, 7 & 8. She says there are never more than 4 calls that appear on the Attendant Console and consequently they are missing calls or they go directly to VM.
Overall Rating: 3.5 (2 ratings)
Chad Stachowicz Wed, 06/25/2008 - 11:14
  • Silver, 250 points or more
There is a utility you can use to change the as user username! its somewhere in the CCM folder on the pub! if this is 4.1...
Chad
mstafford Wed, 06/25/2008 - 13:31
We just tried 5 calls to the main number on Attendant Console and they all show up on the Attendant's screen. So it appears that you really don't need a Pilot Point when configuring Attendant Console.
The only remaining issue is that she can't transfer an incomming call to an internal extension via the console. It can be transferred with the IP phone though. This may just be a limitation of Attendant Console.
Chad Stachowicz Wed, 06/25/2008 - 21:09
ahh so you are right, you can configure Attendant console for a user that does not have a pilot point. The Pilot point is only is you want queing and hunting with log in log out features! however transfers should wrk via the console. its not to a wierd rollover partition is it? Attendent console cannot understand partitions, just DN numbers. So the same DN in multiple partitions messes it up!
HTH,
Chad
mstafford Wed, 07/02/2008 - 07:55
Chad,
Thanks for clarifying that. The numbers on the Attendant's phone are all in the internal partition...No wierd rollover partitions that I know of.
