ACL Logging Missing Packets
Jun 25th, 2008
I'm receiving this error while logging my ACL's. %SEC-6-IPACCESSLOGRL: access-list logging rate-limited or missed XX pacckets.
I know that this means the logging is not reporting some packets, but how would you resolve this issue? I'm logging to syslog, would using a buffer on the routers or switch with this issue resolve it?
jeremyault Wed, 06/25/2008 - 11:20
I think you're just trying to log too much at once. The devices resources are limited and you're over working it.
You could try to be more selective as to what you want to log. I typically only log ACL entries for debugging purposes.
Other than that, maybe someone else can give a better technical solution.
