ACL Logging Missing Packets
Jun 25th, 2008
I'm receiving this error while logging my ACL's. %SEC-6-IPACCESSLOGRL: access-list logging rate-limited or missed XX packets.
I know that this means the logging is not reporting some packets, but how would you resolve this issue? I'm logging to syslog, would using a buffer on the routers or switch with this issue resolve it?
Overall Rating: 5 (1 ratings)
Edison Ortiz Wed, 06/25/2008 - 11:02
Your logging buffer isn't big enough to hold the amount of data that is being sent.
You can increase the logging buffer, please see
for command reference.
If you want to slow down the logging of the message so the buffer won't get full, you need to change the 'ip access-list log-update', see:
Please rate helpful posts
