Debugs...need to get something straight
Jun 25th, 2008
Just have a quick question here:
*Jun 25 18:41:25.628 UTC: IP: s=200.13.119.40 (GigabitEthernet0/1), d=205.248.197.130 (FastEthernet1/0), len 284, access denied
*Jun 25 18:41:25.628 UTC: ICMP type=0, code=0
Am I reading this correctly when I do a ping from the server 205.248.197.130 and it fails. Looking at the above debug tells me the reason why it fails is that on the return trip from 200.13.119.40 sending a reply back to 205.248.197.130 it is using Fastethernet1/0 to try to get back up some sort of access-list is dening the traffic correct?
Overall Rating: 5 (1 ratings)
Edison Ortiz Wed, 06/25/2008 - 11:05
  • Hall of Fame,
    Founding Member
Correct.
__
Edison.
wgranada1 Wed, 06/25/2008 - 11:12
Ok thank you I thought so...now just got to figure out why it is taking the wrong interface....fa0/1 is the wrong interface should be g1/0...anyways thanks for your help!!!!!
