Just Kennie Wed, 06/25/2008 - 11:28
pls tell me what to implement or configure, dont think my comp is ready to pay for any software, unless i will c it free
tdrais Wed, 06/25/2008 - 11:48
The router has limited ability to do collect this.
You can put in
IP route-cache flow on a interface and then show ip cache flow. This will only show open flows not historic data.
You can try configuring the top-talkers with the global command ip flow-top-talkers and it will keep track of flows over a short time.
You can also use ip accounting on the interface which collects more long term data but you will have to process the results results with a external program like excel to get useful data. IP accounting can a performance impact on your router so watch the loads when you first turn it on.
purohit_810 Wed, 06/25/2008 - 19:47
Best solution is sniffer or ethereal that are free utilities.
check the top talkers.
- Dharmesh
