IP Communicator CM6
Jun 25th, 2008
I've been using IPC for a long time and just upgraded to CM6. Now at home over a VPN, I no longer can use IPC. If I call Unity I see packets going both ways, and hear the Unity prompts, but Unity apparently can't hear me. If I call into my CRA IPIVR system, I only show packets from my phone and I don't hear any of the IPIVR Prompts. If I call another CMS subscriber, they can hear me, but I can't hear them. CM6 shows my phone with the IP address of my private network. All of the get.asp instructions state it only applies to Windows. How do I tell CM6 that I'm Natted and really have a 10.X.X.X address?
gogasca Wed, 06/25/2008 - 20:27
  • Green, 3000 points or more
get.asp dont think it may work in 6.x because of Tomcat
Which VPN client you use ?
If you put an sniffer capture which interface we are sending/reciving packets?
Check this common bug for IPC CSCsd69887
