06-25-2008 12:48 PM
I need to connect two MDS SANs switches over dark fiber at a distance of approximately 15 miles (25km). The Long Reach SFPs are rated to 10km. Would I be able to use the CWDM-MUX8A to extend this distance? I'm thinking the answer is no since it is a passive box. Is the ONS15454 my only solution from the Cisco portfolio?
Solved! Go to Solution.
06-26-2008 08:40 AM
If you have plenty of dark fiber, then no reason to use the CWDM muxes on the end. You can connect directly to the dark fibers.
The CWDM SFPs (DS-CWDM-xxxx) support Gigabit Ethernet and 1-Gbps/2-Gbps Fibre Channel.
MDS compatibility matrix:
http://www.cisco.com/en/US/docs/storage/san_switches/mds9000/compatibility/matrix/hwcompat.htm
06-26-2008 11:36 AM
My calculations indicate that you could go at least 60km using the CWDM MUX and longer without the MUX.
I've attached a diagram to try to explain your configuration options (a picture is worth a 1,000 words).
Also, below is a link for the Cisco CWDM MUX devices with more deployment options (for future expansion options).
I hope this helps.
Tom
06-25-2008 05:09 PM
If the MDS switch you have is compatible with a CWDM GBIC (DS-CWDM-xxxx=), then you can use these. These will definitely reach 25km. Are you trying to use only a single dark fiber to bi-directional transmission?
06-26-2008 06:18 AM
I'll have to check compatibility. This is fiber channel, not Gigabit. I have plenty of dark fiber and had anticipated using a pair of fibers for TX/RX.
06-26-2008 08:40 AM
06-26-2008 10:04 AM
Thanks for the reply, baileyshbr. You anticipated my question as to whether or not I needed the Mux. The customer wants 4gig, so I think I'll propose port channeling two of the 2gb ports. I'm sorry for the elementary question, but for port channleing two ports (2 pairs of SM dark fiber), I would use, for example, a pair of DS-CWDM-1470s and a pair of DS-CWDM-1490s? Actually, I guess I could use all DS-CWDM-1470s and have a spare on the shelf.
Am I also correct in assuming that whether or not I use the CWDM MUX will not affect the distance? Meaning I can go up to 60km between my MDS on dark fiber with the DS-CWDM-xxxx?
Thanks again, baileyshbr.
06-26-2008 11:36 AM
I hope this helps.
Tom
06-26-2008 11:55 AM
Excellent. That's just what we needed. We can't tell from the compatibility tables if the MDS 9124 is compatible with the DS-CWDM-xxxx. Do you know?
Thanks again for the PPT and the great information, baileyshbr.
06-26-2008 12:24 PM
I am do not know the MDS product.
Is there a way to run an inventory to find out which model number switch fabric is installed? You might try to post a question on the Data Center connection to find out how you determine which fabric you have and if it is compatible.
Tom
