Temp Fail message on phone screen
Jun 25th, 2008
Latley I've been talking to a user at a remote office and on my phone screen i see a message that says "Temp Fail". Then shortly after that we get disconnected, or it will look as though the call is still active, however neither party can hear one another.
Justin Brenton Wed, 06/25/2008 - 14:27
  • Silver, 250 points or more
Hi Dmobley1022,
This could be caused by the codec your using or by a lack of DSP resources on the Router.
You can use the "show voice dsp" command on the router to view your resources.
You can also search cisco.com for troubleshooting dsp to find a troubleshooting guide for your hardware.
HTH, Please rate.
Justin Brenton
Jaime Valencia Wed, 06/25/2008 - 18:10
  • Cisco Employee,
  • Hall of Fame,
    2011
the message is caused when the phone cannot reach the CUCM server, what are you using for the call? H323 or MGCP? probably you don't have call preservation configured
CCM version?
what's between the phone and the CUCM server
javalenc
if this helps, please rate
kinfai.cheong Tue, 07/01/2008 - 19:30
Hi there,
One of my customer site encounter the same problem on few IP phones.
The gateway is setup using MGCP.
My CCM version is 5.1(3).
I have checked he call preservation you mentioned earlier but does it support on MGCP protocol?
Thanks...
Jaime Valencia Wed, 07/02/2008 - 07:52
  • Cisco Employee,
  • Hall of Fame,
    2011
it does support call preservation, until recently H323 could not do this but now it also can it it, they need to be configured to do this
javalenc
