Sudden Windows DCOM Overflow flood
Jun 25th, 2008
Today, ips-4250-sx (not-in-line) upgraded from v6.0(4)E1 to 6.0(5)E2. (S335) to (S339)
1st appearance & flood of red alerts,
all internal sources and destinations:
1) Windows DCOM Overflow 0&1 subsigs:
(1100src/100dst=86k total hits)
2) Netware LSASS CIFS.NLM Driver Overflow: (145src/140dst=2.5k total hits)
3) Print Spooler Service Overflow: (140src/75dst=2.4k total hits)
- hit accumulation in 7hrs since upgrade
Is there some signature tweaking to be done? or is it TAC time?
Anybody else experience this?
-thanks for any advise
Will
rnaydenov Wed, 06/25/2008 - 23:25
I had the same issue. Just disabled the new signature and wait for better days. as of the new signature sets 341 I see 3 new signatures already disabled. I guess with the next update these new that give us headache will be tuned also
soc_admin Thu, 06/26/2008 - 00:36
Hi Will,
Yes same signatures are firing after S339 and Engine Update! I am quite sure that these are False positives because Windows DCOM BO fires against Domain Controller (I checked and they are healty). Moreover these sig.s started firing just after the update!
I think Cisco is going to tune S339 sig.s.
Marco
shivapd Thu, 06/26/2008 - 06:43
  • Cisco Employee,
Hi Will,
The IPS team is aware of this issue and investigating. An upcoming sig update will address these sigs.
- Shiva
wgorman Thu, 06/26/2008 - 07:24
Shiva,
What is your recommendation?
disable or not
What is the ETA for the sig update?
thanks.
-Will
andytmn Fri, 06/27/2008 - 06:37
I got the same problem after upgrade to 5.1.7E2.
craiwill Fri, 06/27/2008 - 11:12
  • Cisco Employee,
We believe we've identified an engine issue that affects signatures 5588-0,1 and 6769-0. It looks like the easiest work around is to just add the parameter smb command: 37 to the signatures. Due to the nature of the issue detection should not be affected in a negative way. We plan to ship this change in a signature update next week.
david.enenkel Fri, 08/29/2008 - 05:12
How about No.3 the Print Spooler Overflow. Sig 5565. Same workaround ?
Farrukh Haroon Fri, 08/29/2008 - 05:29
  • Red, 2250 points or more
All of these were fixed in S342 I think:
The S342 signature update contains the following modified signature:
PLATFORM SIGID SIGNAME ENGINE SEVERITY ENABLED DDTS
5.x, 6.x 5565.4 Print Spooler Service Overflow SERVICE-SMB-ADVANCED High True CSCsq99671
5.x, 6.x 5588.0 Windows DCOM Overflow SERVICE-SMB-ADVANCED High True CSCsq99671
5.x, 6.x 5588.1 Windows DCOM Overflow SERVICE-SMB-ADVANCED High True CSCsq99671
5.x, 6.x 6769.0 Netware LSASS CIFS.NLM Driver Overflow SERVICE-SMB-ADVANCED High True CSCsq99671
regards
Farrukh
