Bookmarks on clientless SSL VPN
Jun 25th, 2008
I've configured a portal page with a bookmark for a cifs connection to a server. The bookmark shows up okay, but is greyed out and not clickable. I found some info pointing to DNS, citing that the URL must be resolvable via DNS, but I'm using an IP address so that shouldn't be an issue. Any ideas?
portion of the config below
group-policy TestingGroupPolicy internal
group-policy TestingGroupPolicy attributes
banner value This is a test
vpn-tunnel-protocol webvpn
webvpn
url-list value ClientlessSSLVPNBookmark
filter value FileTransferWebACL
customization value FileTransfer
Farrukh Haroon Thu, 06/26/2008 - 00:30
  • Red, 2250 points or more
What is your 'functions' command.
Farrukh
David Niemann Fri, 06/27/2008 - 05:51
Is that valid for 8.x code? I forgot to mention that I'm running 8.0.2
clausonna Tue, 07/01/2008 - 09:06
  • Bronze, 100 points or more
Make sure your CIFS URL includes '\\' for the server.
If you're trying to connect to the share "data" on server "testsvr1", then in the URL field you need to specify:
\\testsvr1\data
So the URL is going to look like cifs://\\testsvr1\data
If you get prompted for credentials then you need to enable single signon.
clausonna Wed, 07/02/2008 - 09:45
Replying to my own post here.
You need to make sure you have dns enabled for your inside interface, so it can resolve the name of the server:
dns domain-lookup Inside
The cifs://testsvr1\data worked on my 8.0(3)19 box, but not on my straight 8.0(3) ASA. I wound up getting the following to work:
cifs://testsvr1/data
