hsrp
joseph.derrick
Would it be possible to use HSRP for two unlike cisco models ? Example, HSRP between ethernet ports of cisco 2600 & 3600.
Thanks !
guruprasadr
Level 7
Level 7
HI Joseph, [Pls RATE if HELPS]
Answer to your question is: YES
Pls RATE if HELPS
Best Regards,
Guru Prasad R
smothuku
Level 7
Level 7
Hi Joseph ,
You can configure HSRP between different paltforms unless until the paltforms supports HSRP.
Before going for hsrp check whether the platforms supports hsrp or not.
Tks,
Satish
