06-25-2008 08:46 PM - edited 03-05-2019 11:49 PM
Dear sirs ,
i have a cisco 3641 router and from the last two days i am not able to telnet this router.
certainly the passwords are changed. i dont know how they changed ?
could you please telll me any way to sort out this.
sanju kumar
06-25-2008 09:32 PM
Hi Sanju ,
If u really don't know the passwords configured on the router then you can go for password recovery procedure in case password recovery is enabled on your router.
Check the below link for password recovery.
you are not able to do telnet is becasue vty lines may not be purged out.
If you are able to login into router using console give the command "clear line " to clear idle vty sessions.
Tks,
satish
06-26-2008 10:16 PM
Hi Sanju,
As Sathish suggested you need to follow the procedure he mentioned in the link to recover the password.
Thought the following link would be helpful in case you want to do password recovery for other products -
http://www.cisco.com/warp/public/474/index.shtml
Using the link above you can browse to the password recovery procedure for most of the Cisco devices.
-> Sushil
06-27-2008 10:07 PM
Dear sushil
Hi thanks for that link.
my question is that after reovering the password router configuration has changed or not?
please suggest me
regards
sanju kumar
06-28-2008 12:47 AM
Sanju
Password recovery does not change the router configuration you already have. All it does is allow you to gain access to your router without having to type in your existing passwords. Once in you can then reset the passwords but the rest of your configuration will stay the same.
Jon
06-28-2008 03:59 AM
dear jon
thanks for this valuable tip
thanks a lot
regards
sanju
