Syslog Verification
Jun 25th, 2008
I have configured syslog on my Catalyst 6509.I have used following commands.
logging buffered 16384
logging trap notifications
logging facility local7
logging 10.112.64.7
service timestamps debug datetime localtime show-timezone msec
service timestamps log datetime localtime show-timezone msec
When i use "sh logging", it shows me only last days messages.I mean to say , i feel, it is not showing me all messages which are logged in Syslog server.
Following is the output, i am getting when i use "show logging"
Syslog logging: enabled (0 messages dropped, 0 messages rate-limited, 0 flushes, 0 overruns)
Console logging: level debugging, 8746 messages logged
Monitor logging: level debugging, 0 messages logged
Buffer logging: level debugging, 5938 messages logged
Exception Logging: size (4096 bytes)
Count and timestamp logging messages: disabled
Trap logging: level notifications, 8768 message lines logged
Logging to 10.112.64.7, 5938 message lines logged
Log Buffer (16384 bytes):
How can i see all messaages logged into syslog server.???
Surya Dathan Thu, 06/26/2008 - 00:04
U mean u want to see all the syslog message in your switch?
In that case, you should issue this command, "logging trap debug". It will see all the message including debugging and information too.
Here is some sample for the syslog message type:
06-26-2008 15:47:42 Local1.Notice 10.50.199.7 473050: Jun 26 15:47:39.582 SGT: %SYS-5-CONFIG_I: Configured from console by net1 onvty0 (10.10.101.26)
06-26-2008 15:47:56 Local1.Info 10.50.199.7 473055: Jun 26 15:47:53.410 SGT: %SEC-6-IPACCESSLOGP: list Network_MGMT permitted tcp 10.50.100.99(45412) -> 0.0.0.0(23), 1 packet
Hope this help. Thanks
satish_zanjurne Thu, 06/26/2008 - 00:23
Hi Subhash,
Thanks for the information.
But your command , just changes the logging level, it will log all messages.
But my query is , i see only last days messages, i want to know, whether my syslog server is logging the messages.???
If it is logging then, if i use "show logging" , why does not it show messages which were logged 2 weeks back for that matter 2 days back ???
