CCM Integration with Unity
Answered Question
Jun 25th, 2008
Dear All,
can i integrate more than one Cisco Call-Manager with one Unified messaging (Unity4.X) ?
Correct Answer by rob.huffman about 8 years 6 months ago
Hi Islam,
Integrations with Multiple Phone Systems
Depending on the version, Cisco Unity can be integrated with two or more phone systems:
•Cisco Unity 4.0 and 4.1 can be integrated with a maximum of two phone systems at one time. For information on and instructions for integrating Cisco Unity with two phone systems, refer to the Dual Phone System Integration Guide at
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_unity/integuid/multi/itmultin.htm
•Cisco Unity 4.2 and later can be integrated with two or more phone systems at one time. For information on the maximum supported combinations and instructions for integrating Cisco Unity with multiple phone systems, refer to the Multiple Phone System Integration Guide at
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_unity/integuid/multi/multcu42.htm
For Unity 4.2;
Maximum Number of Simultaneous Integrations for Each Phone System Type
SCCP
9
SIP
Circuit-Switched via Voice Cards
Circuit-Switched Phone System via Intel PIMG
9
For example, Cisco Unity can be integrated with the following phone systems at one time (a total of seven phone system integrations):
•Three circuit-switched phone systems through PIMG units
•Two Cisco Unified CallManager phone systems through Skinny Call Control Protocol (SCCP)
•One circuit-switched phone system through voice cards
•One Cisco Unified CallManager phone systems through SIP trunk
From this excellent doc;
Multiple Phone System Integration Guide for Cisco Unity 4.2
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/401/integration/guide/multcu42.html#wp1223294
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
Correct Answer
rob.huffman Thu, 06/26/2008 - 05:02
Hi Islam,
For Unity 4.2;
SCCP
9
SIP
9
Hope this helps!
Rob
ranpierce Thu, 06/26/2008 - 05:59
He might be talking about more than one ccm in one cluster. in that case it is one phone system and yes.
rlp, rob is exactly right too
