ASA 5505 dmz newbie
Jun 26th, 2008
Can't seem to figure out how to build a DMZ for our webserver. All trafic gets denied by the default incoming rule.
I want all incoming http/80 requests to the external ip (192.168.10.35 for now) to be forwarded to the www-server in the dmz 176.16.3.15.
I think i have the address translation up and running but no matter what incoming firewall rule i create, trafic gets blocked. I must be missing something obvious here..... any ideas:
ASA Version 8.0(3)
hostname *
domain-name *
enable password *
names
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ip address dhcp setroute
interface Vlan3
nameif dmz-office
security-level 50
ip address 172.16.3.1 255.255.255.0
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
switchport access vlan 3
interface Ethernet0/6
interface Ethernet0/7
passwd encrypted
ftp mode passive
dns server-group DefaultDNS
domain-name
object-group protocol TCPUDP
protocol-object udp
protocol-object tcp
access-list outside-acl extended permit tcp any host 192.168.10.35 eq www
access-list outside_access_in extended permit tcp any host 192.168.10.35 eq www
access-list l2l_list extended permit ip host 192.168.10.35 host 192.168.10.14
pager lines 24
logging enable
logging asdm informational
mtu inside 1500
mtu outside 1500
mtu dmz-office 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-603.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
static (outside,inside) tcp 192.168.1.2 www 192.168.10.35 www netmask 255.255.255.255
static (dmz-office,inside) 172.16.3.14 192.168.10.35 netmask 255.255.255.255
static (inside,dmz-office) 172.16.3.0 172.16.3.0 netmask 255.255.255.0
access-group outside_access_in in interface outside
dhananjoy chowdhury Thu, 06/26/2008 - 01:36
  • Silver, 250 points or more
Give the following command for natting the ip 192.168.10.35(outside) to 172.16.3.15(dmz)
static(dmz,outside) 192.168.10.35 172.16.3.15 netmask 255.255.255.255
robbhanMid Thu, 06/26/2008 - 04:46
Does the nat routing between the VLAN's have to be up and running correctly before I use the packet tracer in the ADSM to see what packets are accepted and/or droped?
It seems like everything gets drop but the default rule
