ASA Config issue
Jun 26th, 2008
We are using ASA Version 7.2(2) Firewall and its configured public IP 122.166.9.59 for external interface. The customer using one remote desktop in side network for accessing from outside .Can we use single public IP for firewall external network and inside remote desktop also, if yes please let me know the configuration.
hostname ciscoasa
enable password xxx
names
interface Vlan1
nameif inside
security-level 100
ip address 192.168.0.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address 122.166.9.59 255.255.255.0
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
shutdown
interface Ethernet0/3
shutdown
interface Ethernet0/4
shutdown
interface Ethernet0/5
shutdown
interface Ethernet0/6
shutdown
interface Ethernet0/7
shutdown
access-list 101 extended permit tcp any host 122.166.9.59 eq 3389
pager lines 24
mtu inside 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
nat-control
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
static (inside,outside) 122.166.9.59 192.168.0.10 netmask 255.255.255.255
access-group 101 in interface outside
route outside 0.0.0.0 0.0.0.0 122.166.9.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
http 192.168.0.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
telnet 192.168.0.0 255.255.255.0 inside
telnet timeout 5
ssh timeout 5
console timeout 0
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
a.alekseev Fri, 06/27/2008 - 03:57
  • Gold, 750 points or more
conf t
no static (inside,outside) 122.166.9.59 192.168.0.10 netmask 255.255.255.255
static (inside,outside) tcp interface 3389 192.168.0.10 3389 netmask 255.255.255.255
ntmanjunath Fri, 06/27/2008 - 07:03
This will work for both external firewall ip and internal remote desktop acess from out side ?
