06-26-2008 02:18 AM - edited 07-03-2021 04:04 PM
Does anyone know how long the data collection process takes during the calibration process for lbs? I have read in the design guide (4.1) that it can take up to "a few minutes". Is this per data collection point? If so, how far apart are these suggested data collection points?
Justin
06-26-2008 03:26 AM
It's for each data collection point. I have tried this running WLC 4.1.112 and LA 3.1.36 and applied to to 8 floors. The result was worse than when I let the LA do it's own calibration it has. So I ened up removing the calibration from the map. I tried it again with another client and got the same results.... worse than if I left it alone. Try it on a certain floor first and compare before you complete everything.
06-26-2008 05:12 AM
Ok thanks for the input.
One more question. I will be using AeroScout Mobile View as well. I imagine that the calibration process would be the same (via the WCS)?
06-26-2008 05:17 AM
It might be slightly different. find out from AeroScout regarding their best practice.
