IPS 4255 IDM Problem
Jun 26th, 2008
I've a IPS 4255 with the version 6.0(3) and when t try to acess the IPS through HTTPS - IDM appers this error in Java Console(1.6.0_05-b13):
"Invoking SGZ Loader...
java.net.SocketException:Unexpected end of file from server"
and i can't connect to my IPS.
I don't understand why...
Vitor
Farrukh Haroon Thu, 06/26/2008 - 05:07
  • Red, 2250 points or more
Try to download the latest release of 1.6 or add an additional installation of java 1.5. Then in your browser select that (IE >> Internet Options >> Advanced >> Java) then reboot the browser.
Also I hope you increasing the memory using -Xmx256m in Control Panel >> Java >> ...
It should be OK then.
You can also try an 'alternate' browser like Mozilla Firefox (if u're using IE) or vice versa.
Farrukh
