Upgrade Check
Jun 26th, 2008
Current setup- can anyone confirm the below
3 X CM 4.13
2 X IPCC 4.04 (HA)
1X Unity 4.05
CM upgrade to 6.1(2) current HW = MCS-7845-I1-IPC1 (no HW upgrade required)
IPCC upgrade to 5.0(2) current HW = MCS-7835-H1-IPC1 (no HW Upgrade required)
Direct upgrade for CM - using DMA
No upgrade path for IPCC from 4.04-5.0
will need to perform fresh install?
Will I be able to load all scripts created in v4.04 straight into v5.02?
No Unity upgrade required
thanks
Overall Rating: 5 (1 ratings)
Chris Deren Thu, 06/26/2008 - 10:28
Your severs will be OK, ensure that they have at least 2 Gb or RAM and 72 Gig drives.
The scripts will work, I suggest that you open them up in new script editor and save to the repository. Alos, dont remember to copy prompts, docuemnts, etc, and any CAD settings.
HTH, please rate all useful posts!
Chris
Aaron Dhiman Wed, 07/02/2008 - 11:47
I have run the Upgrade Assistant on servers that have 32G drives, and it passed. Do you think that is a mistake by the Upgrade Assistant, or does the 72G drive requirement relate to total drive space, including redundant drives in the Array?
Jaime Valencia Wed, 07/02/2008 - 12:28
there are some servers that pass the test but the Release Notes explain that for those servers you need to upgrade either RAM or HDD for them to work. meaning that if the server has 1 GIG if you upgrade to the minimum required of 2 gigs it will work.
javalenc
if this helps, please rate
Chris Deren Wed, 07/02/2008 - 12:49
This is normal as the upgrade assistant is probably for CM 4.2 or 4.3 which has different requirements from CM 5/6.
HTH,
Chris
