mahmoodmkl Thu, 06/26/2008 - 04:21
  • Gold, 750 points or more
The routed port cannot be a memember of a vlan.
Mahmood
tomek0001 Thu, 06/26/2008 - 10:01
You might look at using a BVI, bridged virtual interface if you are trying to "connect" routed ports. With a BVI you are adding the routed interfaces to a bridge group as in a Layer 2 bridge back in the old days of the Ethernet.
Check out this link for more help:
http://www.cisco.com/univercd/cc/td/doc/product/l3sw/8540/rel_12_0/wx5_11a/config/7cfg8500.htm
(please rate if you found this useful)
