dial-peer question
Jun 26th, 2008
dial-peer voice 11 voip
voice-class h323 1
incoming called-number 1#
tech-prefix 1#
dtmf-relay h245-signal
fax-relay ecm disable
fax rate 14400
no vad
Is this dial-peer working- as there is no session target or port1/1 .....
many thanks
