Unity Audio Issues
Jun 26th, 2008
We are having a problem on our network where UDP packets with duplicate sequence numbers are being recieved by our Unity systems. It appears that Unity does not discard these packets. This is resulting in a messages that are degraded in quality. The call sounds like they are talking very slow. If you press 6 on the key pad you can speed the messsage up so it almost sounds normal. Of course we have to fix our network problem but is it normal for Unity not to drop packets with duplicate sequence numbers?
Thanks!
Steve
