06-26-2008 04:44 AM - edited 03-05-2019 11:50 PM
Hi. I'd like to give my laptop a public IP and my 877 a public IP for test purposes.
However i seem to be falling over at the first step, my router can't seem to ping any sites. Here's the config. Any ideas?
Building configuration...
Current configuration : 3284 bytes
version 12.4
no service pad
hostname inetrtr
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
dot11 syslog
ip cef
ip domain name yourdomain.com
ip name-server 62.x.40.178
ip name-server 194.x.0.98
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
username micross privilege 15 secret xxx
archive
log config
hidekeys
interface ATM0
no ip address
no ip route-cache cef
no ip route-cache
no ip mroute-cache
no atm ilmi-keepalive
pvc 0/38
encapsulation aal5mux ppp dialer
dialer pool-member 1
dsl operating-mode auto
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Dialer0
ip address 217.34.x.x 255.255.255.248
no ip redirects
no ip unreachables
no ip proxy-arp
encapsulation ppp
dialer pool 1
dialer idle-timeout 0
dialer persistent
no cdp enable
ppp authentication chap callin
ppp chap hostname hostname
ppp chap password 0 password
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer0 track 1
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
no cdp run
control-plane
line con 0
login local
no modem enable
line aux 0
line vty 0 4
privilege level 15
login local
transport input telnet ssh
scheduler max-task-time 5000
end
06-26-2008 05:06 AM
hi,
my sugsestion - change default route to IP address of gateway, route to interface Dialer with Your mask is bad idea
regards
romek
06-26-2008 07:20 AM
hi mate, so you mean find out the gatway from our DSL supplier and make my default route that IP address?
06-26-2008 10:56 PM
hi,
yes, route to interface is possible only on point-to-point connections
regards
romek
