UC500 Italian language for CUE ise
Jun 26th, 2008
Hello everibody,
I'm tring again and again to install Italian prompt language for AA in UC500. CUE version is ise 3.0.3 and the file I got is cue-vm-it_IT-langpack.ise.3.0.3.prt1.
Now I tried with several different kind of installation with CCA 1.6 but none was ok.
Is there a simple way to installa the italian language?
Thank you everibdy
paolo bevilacqua Thu, 06/26/2008 - 07:10
  • Hall of Fame,
    Founding Member
CCA can fail doing installs correctly. Use the CLI as described in the CUE documentaion to load the language pack.
