CSM 3.2 and deployment schedule
Jun 26th, 2008
Hi all,
How do you remove a suspended active deployment schedule entry from the deployment schedule table. I have checked the CSM 3.2 user guide and can see that you can suspend it without discarding it and then re-activate it later but how do you remove an entry from the schulde if you no longer need it?
smahbub Wed, 07/02/2008 - 06:16
  • Silver, 250 points or more
In Workflow mode, you can discard a job when it is in any state except Deployed, Deployment Failed, or Aborted. The job state is shown as discarded until the job is purged from the system, either automatically as set on the Workflow Management page or manually.
Refer the following url for more information on deployment management in CSM 3.2:
http://www.cisco.com/en/US/docs/security/security_management/cisco_security_manager/security_manager/3.2/user/guide/dpman.html#wp665851
