Dynamic Site to Site Tunnel
Jun 26th, 2008
What would need to be changed for this to be dynamic?
access-list 100 extended permit ip 172.25.2.0 255.255.255.0 10.100.2.0 255.255.255.0
access-list nonat extended permit ip 172.25.2.0 255.255.255.0 10.100.2.0 255.255.255.0
nat (inside) 0 access-list nonat
crypto ipsec transform-set myset esp-3des esp-sha-hmac
crypto map outside_map 20 match address 100
crypto map outside_map 20 set peer xx.xxx.xxx.101
crypto map outside_map 20 set transform-set myset
crypto map outside_map interface outside
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
tunnel-group xx.xxx.xxx.101 type ipsec-l2l
tunnel-group xx.xxx.xxx.101 ipsec-attributes
pre-shared-key ciscorules
rmwhite59 Thu, 06/26/2008 - 07:30
Clarification:
ASA has a static IP
PIX has a dynamic IP
I need to create a site to site tunnel between them
acomiskey Thu, 06/26/2008 - 07:45
  • Green, 3000 points or more
On the ASA, use the DefaultL2LGroup, don't create a tunnel group with ip address of the pix, as it will change.
tunnel-group DefaultL2LGroup ipsec-attributes
pre-shared-key *
and...
crypto dynamic-map dyn_map 10 match address 100
crypto dynamic-map dyn_map 10 set pfs
crypto dynamic-map dyn_map 10 set transform-set myset
crypto map outside_map 20 ipsec-isakmp dynamic dyn_map
