CCX 5.0 Supervisor Desktop Barge greyed out
Jun 26th, 2008
Is there specific configuration that needs to be in place for Barge-In and Intercept to be enabled?
The two buttons are greyed out evne when an Agent is on a call. Where do I select in the Agent Pane to be able to Barge/Intercept a call from the Supervisor Desktop?
I am running Build 6.4.2.12 on Unified Contact Center Express 5.0 Supervisor Desktop 5.0 (Enhanced Version).
thanks in advance!
Chris Deren Thu, 06/26/2008 - 11:52
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
You have to first select the agent call before it gets enabled, it's a little tricky the first time :-)
Chris
