ACE One-Arm Mode - NAT
Jun 26th, 2008
Hopefully someone can help me here.
I am trying to load balance a set of servers and need to do this in a one-arm mode configuration.
Client - Router - ACE - Router - Server Farm
I cannot get ACE to change the SRC address of the packet before it gets sent to the server farm. Appears that ACE makes the load balance decision and forwards the packet on. Doing traces, I see that the server is responding directly to the client and not to the ACE.
Can someone post a config in which they have implemenet both Load Balancing and NAT like I want to do above.
Again, I want to change the SRC address before it gets sent to the server farm.
Phil
Syed Iftekhar Ahmed Thu, 06/26/2008 - 15:09
  • Blue, 1500 points or more
Lets assume that your client vlan (where the VIP resides) is vlan 10 and server vlan is vlan 20 then you need following config
policy-map multi-match VIPS
class VIP-APP1
loadbalance vip inservice
loadbalance SLB_LOGIC
nat dynamic 1 vlan 20
interface vlan 10
description Client vlan
ip address 10.10.10.1 255.255.255.0
service-policy input VIPS
no shutdown
interface vlan 20
description Servers vlan
ip address 20.20.20.1 255.255.255.0
nat-pool 1 20.20.20.10 20.20.20.20 netmask 255.255.255.0
no shutdown
nat-pool is always configured on the egress traffic interface.
If ACE is connected via a single vlan (One arm mode) the both service policy and nat pools will be applied on the same interface.
class VIP-APP1
nat dynamic 1 vlan 10
interface vlan 10
description Onearm vlan
no shutdown
Best place to ask ACE related questions is "Data center" area.
Syed Iftekhar Ahmed
phil.wightman Fri, 06/27/2008 - 08:47
Ok, that is how I have it configured and it does not work. The ACE passes the client IP onto the server. The server attempts to respond directly back to the client!! Maybe I did something wrong?? Looking at my network traces, it is not using the NAT ip's. Now I have gotten it to work if I put the server on the same segment as the ACE and put the LoadBalance and the NAT statements in different Class-Maps referenced the 2 Class-Maps in the same Policy Multi-Match. I need for the Client, ACE, and Server to all be on different segments. I will post that config if you care to see it. Here is the config as suggested that does not do NATing....
access-list EVERYONE line 1 extended permit ip any any
rserver host Server1
ip address 10.10.10.100
inservice
serverfarm host WEBFARM
rserver Server1 80
inservice
class-map type management match-any MGMT-POLICY
201 match protocol snmp any
202 match protocol xml-https any
203 match protocol telnet any
204 match protocol ssh any
205 match protocol icmp any
206 match protocol https any
207 match protocol http any
class-map match-any VIP-10
2 match virtual-address 10.10.10.20 any
policy-map type management first-match MGMT-POLICY
class MGMT-POLICY
permit
policy-map type loadbalance first-match VIP-10-l7slb
class class-default
serverfarm WEBFARM
policy-map multi-match NAT-POLICY
class VIP-10
loadbalance policy VIP-10-l7slb
interface vlan 10
ip address 10.10.10.15 255.255.255.0
access-group input EVERYONE
nat-pool 1 10.10.110.30 10.10.110.35 netmask 255.255.255.0 pat
service-policy input NAT-POLICY
no shutdown
interface vlan 5
ip address 10.10.5.15 255.255.255.0
service-policy input MGMT-POLICY
no shutdown
ip route 0.0.0.0 0.0.0.0 10.10.5.1
snmp-server contact "ANM"
snmp-server location "ANM"
snmp-server community public group Network-Monitor
snmp-server trap-source vlan 5
Syed Iftekhar Ahmed Fri, 06/27/2008 - 09:48
I think its your default route.
Due to default route traffic is egressing through wrong interface.
If you are in one arm mode shouldnt the default route be pointing towards 10.10.110.x gateway?
You can also try using "mac-sticky enable" under the vlan configuration if you canont change the default gateway. This will make sure that the same interface will be used for return traffic where the request was recieved.
Syed
phil.wightman Fri, 06/27/2008 - 12:13
That is exactly what it was. Cant beleive I overlooked that. In bridged mode and routed mode the default gateway does not matter so I never bothered with it. Thank you for your help!
Syed Iftekhar Ahmed Fri, 06/27/2008 - 12:16
I am glad it helped.
Just to let you know "Data Center section" is the right place to ask ACE related questions.
Syed
