Internal calling only extension mobility
Jun 26th, 2008
We are testing out extension mobility for one group within our organization. We are trying to set it up so that when a user logs out of a phone, the phone defaults to a differnet DN which so far we have gotten to work. I'm trying to make it so that the DN that gets assigned to the phone when nobody is logged into it can only dial internally. Does anybody have any links to documents that detail how to setup either the device profile to only permit internal calls or setup a line that can be associated with that profile that can only make internal calls? From what I have found, it looks like I will need to create a different CSS for internal only and a route filter for internal calls only but my attempts thus far have not worked so if anybody has any pointers I would greatly appreciate it.
Thanks, Matt
Jaime Valencia Thu, 06/26/2008 - 07:19
  • Cisco Employee,
  • Hall of Fame,
    2011
i dont' believe there is a doc on that, it all comes down to CSS and partitions. no other thing
to dial internal assign a CSS with the internal partition on which phones are
javalenc
if this helps, please rate
