After restore not able to log in on CCM 4.1(3)
goranpilat
Level 3
Level 3
Hello all,
Recently I did 4.1(3) restore on a new machine. The old machine which was backed up was integrated with AD. As I did restore on the new machine (which wasn't plugged in the network where AD is), I can't log in anymore. Seems that CCM is looking for the users on AD which is unavailable. Any way to tell him not to search users in AD?
thanks for any kind of answer,
regards,
goran pilat
use ccmpwdchanger, but that needs to be connected to the AD.
disable MLA in the DB and get in with the pwd from the box
javalenc
if this helps, please rate
java
Jaime Valencia
How to Change Active or Netscape Directory Integration Back to DC Directory in CallManager
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00800ab82d.shtml
javalenc
java
Which password do I use then to log into CallManager? Neither of them seems to be working. How do I change CCMAdministrator password?
thanks,
goran
javalenc
java
Yup, thanks a lot, that is it. And here's the link how to do that...
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00800e1691.shtml#newtopic
regards,
