SRST doesn't work
webstd.design
Config
isdn switch-type primary-4ess
voice-card 0
no dspfarm
voice translation-rule 1
rule 1 /74381/ /131/
rule 2 /743648/ /1304/
rule 3 /74380/ /130/
voice translation-rule 2
rule 1 /13/ /5367438/
voice translation-profile 1
translate called 1
voice translation-profile 2
translate calling 2
application
global
service alternate DEFAULT
controller E1 0/0/0
framing NO-CRC4
pri-group timeslots 1-31 service mgcp
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn overlap-receiving
isdn incoming-voice voice
isdn bind-l3 ccm-manager
isdn sending-complete
no cdp enable
access-list 111 deny tcp 10.XXXXX 0.0.0.255 host xxxx eq 2000
access-list 111 deny tcp 10.XXXXX 0 0.0.0.255 host xxxx eq 2428
access-list 111 deny udp 10.XXXXX 0 0.0.0.255 host xxxx eq 2427
access-list 111 permit ip any any
voice-port 0/0/0:15
translation-profile incoming 1
translation-profile outgoing 2
cptone RU
voice-port 0/1/0
voice-port 0/1/1
ccm-manager fallback-mgcp
ccm-manager redundant-host XXXX
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server XXXX
ccm-manager config
mgcp
mgcp call-agent XXXX 2427 service-type mgcp version 0.1
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface GigabitEthernet0/1.10
mgcp bind media source-interface GigabitEthernet0/1.10
mgcp profile default
dial-peer voice 80 pots
incoming called-number .
direct-inward-dial
port 0/0/0:15
dial-peer voice 3 pots
tone ringback alert-no-PI
destination-pattern 80.........
no digit-strip
direct-inward-dial
port 0/0/0:15
dial-peer voice 4 pots
destination-pattern 82.......
no digit-strip
direct-inward-dial
port 0/0/0:15
dial-peer voice 6 pots
destination-pattern 0[0456789].
no digit-strip
direct-inward-dial
port 0/0/0:15
dial-peer voice 5 pots
destination-pattern [23]....
no digit-strip
direct-inward-dial
port 0/0/0:15
dial-peer voice 7 pots
destination-pattern 7.....
no digit-strip
direct-inward-dial
port 0/0/0:15
call-manager-fallback
max-conferences 8 gain -6
ip source-address XXXX port 2000
max-ephones 24
max-dn 48
transfer-pattern 0.
transfer-pattern 0..
transfer-pattern 2....
transfer-pattern 3....
transfer-pattern 7.....
transfer-pattern 82.......
transfer-pattern 80.........
keepalive 10
end
8 Replies 8
webstd.design
When I use ACL
access-list 111 deny tcp XXXX 0.0.0.255 host IPADDRESS_OF_CALLMANAGER1 eq 2000
access-list 111 deny tcp XXXX 0.0.0.255 host IPADDRESS_OF_CALLMANAGER2 eq 2000
access-list 111 deny tcp XXXX 0.0.0.255 host IPADDRESS_OF_CALLMANAGER1 eq 2428
access-list 111 deny tcp XXXX 0.0.0.255 host IPADDRESS_OF_CALLMANAGER2 eq 2428
access-list 111 deny udp XXXX 0.0.0.255 host IPADDRESS_OF_CALLMANAGER1 eq 2427
access-list 111 deny udp XXXX 0.0.0.255 host IPADDRESS_OF_CALLMANAGER2 eq 2427
Phone registering on the gateway, but when I try to call nothing happens
debug voice translation
Jun 26 15:30:58.233: //-1/xxxxxxxxxxxx/RXRULE/regxrule_get_profile_from_trunkgroup_internal: Voice port 0x46546104 does not belong to any trunk group
Jun 26 15:30:58.233: //-1/B5877A80834B/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x46B4C3A8; count=1
Jun 26 15:30:58.241: //-1/B5877A80834B/RXRULE/regxrule_stack_push_RegXruleNumInfo: stack=0x46B4C3A8; count=0
Jun 26 15:30:59.249: //-1/B5877A80834B/RXRULE/regxrule_stack_push_RegXruleNumInfo: stack=0x46B4C3A8; count=1
Jun 26 15:30:59.249: //-1/B5877A80834B/RXRULE/regxrule_dp_translate: No profile found in peer 7 for outgoing direction
Jun 26 15:30:59.249: //-1/B5877A80834B/RXRULE/regxrule_dp_translate: calling_number=1306 calling_octet=0x0
called_number=743807 called_octet=0x80
redirect_number= redirect_type=0 redirect_plan=0 redirect_PI=0 redirect_SI=0
Jun 26 15:30:59.249: //-1/B5877A80834B/RXRULE/regxrule_get_profile_from_voiceport_internal: Found profile 2 defined on voice-port
Jun 26 15:30:59.249: //-1/B5877A80834B/RXRULE/regxrule_profile_translate_internal: number=1306 type=unknown plan=unknown numbertype=calling
Jun 26 15:30:59.249: //-1/B5877A80834B/RXRULE/regxrule_profile_match_internal: Matched with rule 1 in ruleset 2
Jun 26 15:30:59.249: //-1/B5877A80834B/RXRULE/sed_subst: Successful substitution; pattern=1306 matchPattern=13 replacePattern=5367438 replaced pattern=536743806
Jun 26 15:30:59.249: //-1/B5877A80834B/RXRULE/regxrule_subst_num_type: Match Type = none, Replace Type = none Input Type = unknown
Jun 26 15:30:59.249: //-1/B5877A80834B/RXRULE/regxrule_subst_num_plan: Match Plan = none, Replace Plan = none Input Plan = unknown
Jun 26 15:30:59.249: //-1/B5877A80834B/RXRULE/regxrule_profile_translate_internal: xlt_number=536743806 xlt_type=unknown xlt_plan=unknown
Jun 26 15:30:59.249: //-1/B5877A80834B/RXRULE/regxrule_profile_translate_internal: number=743807 type=unknown plan=unknown numbertype=called
Jun 26 15:30:59.249: //-1/B5877A80834B/RXRULE/regxrule_get_RegXrule: Invalid translation ruleset tag=0
Jun 26 15:30:59.249: //-1/B5877A80834B/RXRULE/regxrule_profile_match_internal: Error: ruleset for called number not found
Jun 26 15:30:59.249: //-1/B5877A80834B/RXRULE/regxrule_profile_translate_internal: No match: number=743807 type=unknown plan=unknown
Jun 26 15:30:59.249: //-1/B5877A80834B/RXRULE/regxrule_profile_translate_internal: number= type=unknown plan=unknown numbertype=redirect-called
Jun 26 15:30:59.249: //-1/B5877A80834B/RXRULE/regxrule_profile_match_internal: Error: ruleset for redirect-called number not found
Jun 26 15:30:59.249: //-1/B5877A80834B/RXRULE/regxrule_profile_translate_internal: No match: number= type=unknown plan=unknown
Jun 26 15:30:59.249: //-1/B5877A80834B/RXRULE/regxrule_vp_translate: calling_number=536743806 calling_octet=0x0
Jun 26 15:31:00.517: //-1/B5877A80834B/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x46B4C3A8; count=2
Jun 26 15:31:02.773: //-1/xxxxxxxxxxxx/RXRULE/regxrule_get_profile_from_trunkgroup_internal: Voice port 0x46546104 does not belong to any trunk group
Jun 26 15:31:02.777: //-1/B83C4D2A834E/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x46B4C0B4; count=1
Jun 26 15:31:02.777: //-1/B83C4D2A834E/RXRULE/regxrule_stack_push_RegXruleNumInfo: stack=0x46B4C0B4; count=0
Jun 26 15:31:04.557: //-1/B83C4D2A834E/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x46B4C0B4; count=1
internal Number 1306 replaced by external 536743806. But this number doesn't see PRI
What number is being sent out of the PRI after the translation is done. What does debug isdn q931 say? Is this an incoming call or an outgoing call?
it is outgoing call.
debug isdn q931 saying nothing
when I try to call number from city
debug isdn q931 says that Destination is out of order
The debug says that you are dialing 743807. Is that what is being sent out of the PRI?
536743806 - it's needed number and it's good from debug voice translation
Can any body help me???? or no?
