06-26-2008 07:54 AM - edited 03-15-2019 11:33 AM
Guys,
I am trying to use BAT to add new phones, however I get the following errors..
Insert Phones - All Details
Begin Time : 06/26/2008 16:20:31
Query :
Insert Phones in /common/bps/csvfiles/phones/insert/all/bat1.txt
Failure Details :
MAC Address/Device Name Error Code Error Description
1231123245AB DEVICE :: Error : 407 The Model type for the specified Product type was not found
1231123425AB DEVICE :: Error : 407 The Model type for the specified Product type was not found
Result Summary :
INSERT for 0 PHONES passed.
INSERT for 2 PHONES failed.
End Time : 06/26/2008 16:20:32
Here are the steps I used.
1. Downloaded the BAT.xlt
2. After adding my entries, I exported to BAT format.
3. Uploaded the file and ran the job
However I do not know how to input the phone model type.
when I added 7960 on the select Model Column, I get same error, I tries Cisco 7960 too same error.
Is there something else to do to add the phone type?
06-26-2008 08:04 AM
try 7960G
javalenc
if this helps, please rate
06-26-2008 08:10 AM
same error...No joy!
06-26-2008 08:10 AM
Hey Deji,
Hope all is well my friend! Did you create a Template for the 7960?
BAT Configuration Process
BAT uses a multistep process to prepare the bulk configuration transaction. BAT uses a Bulk Administration menu options, to guide you through the configuration tasks. The BAT process includes these tasks:
1. Set up the template for data input.
2. Define a format for the CSV data file.
3. Collect the data for each device in the bulk transaction.
4. Upload the data files choosing the relevant target and function for the transaction.
5. Validate the data input files with the Cisco Unified CallManager database.
6. Submit jobs for execution.
7. Schedule jobs.
8. Execute jobs to insert the devices into the Cisco Unified CallManager database.
Using BAT Templates
As the first task in the BAT configuration process, you set up a template for the devices that you are configuring. You specify the type of phone or device that you want to add or modify, and then you create a BAT template that has features that are common to all the phones or devices in that bulk transaction.
You can create BAT templates for the following types of device options:
â¢Phones: All Cisco Unified IP Phone models and Cisco ATA 186, Cisco VGC phones, CTI ports, and H.323 clients.
â¢Gateways: Cisco VG200 and Cisco Catalyst 6000 FXS Analog Interface Module
â¢User Device Profiles: Cisco Unified IP Phone 7900 series and Cisco SoftPhone
Define a BAT template by specifying values in the template fields that will be common to all the devices in the bulk transaction. The BAT template fields require similar values to those that you enter when you are adding a device in Cisco Unified CallManager Administration.
Prior to creating the BAT template, make sure settings such as device pools, locations, calling search spaces, button templates, and softkey templates have already been configured in Cisco Unified CallManager Administration.
After you create a BAT template, you save it with a name. Later in the configuration process, you associate the template name with the CSV data file. The system stores the templates, so they are reusable for future bulk transactions. For example, you can configure a Cisco IP Phone 7960 template with a specific button template and calling search space and then configure another Cisco IP Phone 7960 template with a different button template and the Extension Mobility feature enabled. When you need to add a large number of phones with the same configuration, you can reuse the existing BAT template.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/bat/5_1_3/t01batow.html#wp1040070
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/bat/5_1_3/t03phtmp.html
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/bat/5_1_3/t03inph.html
Hope this helps!
Rob
06-26-2008 08:19 AM
Rob, thanks for this excellent doc. However I did try to use a phone template I created, but I get this error:
Insert Phones - Specific Details
Begin Time : 06/26/2008 17:19:41
Query :
Insert Phones in /common/bps/csvfiles/phones/insert/specific/bat5.txt
Failure Details :
1231123245AB Line number 1 is not configured on the template.
1231123425AB Line number 1 is not configured on the template.
Result Summary :
End Time : 06/26/2008 17:19:42
I do not believe I have to configure DN on each phone template. Because then the Purpose of BAT will be defeated...is there something I am missing
06-26-2008 08:28 AM
Hi Deji,
You are most welcome, but obviously this didn't help :(
Go back and have a close look at the template you created. Specifically look at the number of lines you setup for this Template (1-6). You need to match the Template # of lines with what you have configured in the .csv
Hope this helps!
Rob
06-26-2008 08:36 AM
Rob,
Even after I added a 2nd line to the csv file to match the Phone template line numbers, it still failed with the same error..
Begin Time : 06/26/2008 17:35:15
Query :
Insert Phones in /common/bps/csvfiles/phones/insert/specific/bat6.txt
Failure Details :
Result Summary :
End Time : 06/26/2008 17:35:18
However when I added a DN to the phone template line, it went ok. But the trouble is that. I will then manually need to add DN for 80-100 phones, which I believe shouldnt be..
06-26-2008 08:45 AM
Hi Deji,
I don't think so :) The DN entered via the .csv will override the template info. Give it a try.
Hope this helps!
Rob
06-26-2008 08:49 AM
Rob,
The file I am using is not a .csv. it is a .txt. This is the file created using the bat.xlt file. Is this a problem. I have tried using the DN in the .txt file...and no joy!
06-26-2008 08:56 AM
is the bat.xlt the one from that specific CUCM version?? i mean did you downloaded it from that server?
can you upload the csv?
javalenc
06-26-2008 09:10 AM
attached is the CSV file.
When I did a validate on the file I got this error:
Validate Phones - Specific Details
Begin Time : 06/26/2008 18:07:12
Failure Details :
Device Name/MAC Address Error Code Error Description
2001 CSV contains more number of lines than are supported by the phone template.
Result Summary :
VALIDATE for 0 PHONE passed.
VALIDATE for 2 PHONE failed.
End Time : 06/26/2008 18:07:13
06-26-2008 09:15 AM
open the file, press ctrl + end
delete the last row that is there and try again
javalenc
06-26-2008 09:21 AM
after deleting the last row ( i believe this is the row that points to the 2nd phone)(i have atatched the new file)
I still get this error:
Begin Time : 06/26/2008 18:20:45
Query :
Insert Phones in /common/bps/csvfiles/phones/insert/specific/bat7.txt
Failure Details :
Result Summary :
INSERT for 1 PHONES failed.
End Time : 06/26/2008 18:20:45
06-26-2008 09:32 AM
still blanks on the file, do not leave blanks, when you press ctrl + end you should be at the last char of the 2nd line
verify the configuration of line 1 on your template
javalenc
06-26-2008 09:46 AM
Now I have removed all the blanks. Yet teh error about line 1 on the tyemplate is still there.
"1231123245AB Line number 1 is not configured on the template"
The only way I have managed to avoid the error is by configuring a DN on the Line 1 of the Phone template I am using.
If this is the way its designed to work, then it does not help beacuse imagine that I have 100 phones each with 2 DN, I will have to configure 200 Phones, which defeats the purpose of BAT
attached is the new file, no blanks
