unable to access controller via http/ssh
j.delossantos
We are running 4.2.112 code on the 2 controllers on our WiSM blade. While making multiple ldap/local EAP changes on one of the controllers via http, that particular controller becomes inaccessible via http/ssh but it still processes traffic and it can still be configured by using WCS. We just reboot from WCS to regain access.
Is this a known bug? Anyone else experiencing the same problem?
What is the most stable code release?
Thanks in advance for any input.
Scott Fella
I haven't heard of that issue on any 4.1 or 4.2 code.. only 5.0. If you don't have any 1252 ap's to support, 4.1.185 is a very stable code.
-Scott
can you get to the controller from the 6500 via
"session slot xx processor yy" ?
where xx is the blade number and yy is 0 or 1.
and/or does it recover on its own after awhile ?
I have seen lack of connectivity but it does recover.
Scott,
Good info, thank you. Yes we do not have 1252s but I think we will need the LDAP features of 4.2. Does 4.1.185 have similar LDAP features as 4.2?
Robert,
I haven't tried that since it is much easier to just reboot, it's just a test setup for now. But I will try it your suggestion the next time it occurs.
Thanks to both of you.
