LAP WLC message
Jun 26th, 2008
Hi, I see this logs in my access points:
*Jun 26 11:59:18.115: LWAPP_CLIENT_ERROR: lwapp_name_lookup - Could Not resolve CISCO-LWAPP-CONTROLLER
What is the meaning of this messages?
Overall Rating: 3.7 (3 ratings)
Scott Fella Thu, 06/26/2008 - 09:20
It's the ap trying to discover a controller via dns. You have a wireless lan controller? You need one with this type of ap. If you look at the model number printed on the back of the ap, you will see LAP1242 or LAP1131, these are lightweight ap's. If you want autonomous ap's you need AP1242 or AP1131. Don't know what type of ap you have. You can convert LAP's to autonomous.
ricardorojas123 Thu, 06/26/2008 - 09:38
Hi, yes is the LAP model 1131, and I have a WLC version 5. I would like configure discover via DNS, you known, How I can do it?
Scott Fella Thu, 06/26/2008 - 09:43
All you have to do is add a dns entry for with an ip address of one of your wlc management interface.
Robert Rowland III Thu, 06/26/2008 - 09:40
In your corporate DNS add an A record of
CISCO-LWAPP-CONTROLLER with the IP address of the controller. You can also do this with DHCP options but some people find the DNS easier.
ricardorojas123 Thu, 06/26/2008 - 10:40
OK, I will configure the LAP with address statics and add the IP Managment as CISCO-LWAPP-CONTROLLER in the DNS.
ricardorojas123 Thu, 06/26/2008 - 11:25
Hi, I have another question is the following log:
AP001d.e557.280c#lwapp ap ip address
ERROR!!! Command is disabled
Because this command is disable, the log is from the LAP1131.
Scott Fella Thu, 06/26/2008 - 12:35
This is because the ap has joined a wlc already.
Here is from another thread:
First, check the flash:
Directory of flash:/
2 -rwx 279 May 09 2008 11:52:20 +00:00 env_vars
4 -rwx 6168 May 09 2008 11:52:20 +00:00 private-multiple-fs
6 drwx 256 May 09 2008 11:49:05 +00:00 c1130-k9w8-mx.124-3g.JA2
5 drwx 128 Mar 01 2002 00:03:43 +00:00 c1130-rcvk9w8-mx
15998976 bytes total (10716672 bytes free)
Then delete the LWAPP image:
lap_1131#delete /r /f flash:/c11310-k9w8-mx.124-3g.JA2
Not the one the has rcv in it!!!!!!
Thirdly reload the AP:
Then issue a clear lwapp private-config
You'll end up with a clear AP. - Mobility&topic=General&topicID=.ee6e8b8&fromOutline=&CommCmd=MB?cmd=display_location&location=.2cbf883c
ricardorojas123 Thu, 06/26/2008 - 17:27
I configured the AP with static address:
lwapp ap ip address
lwapp ap ip defaul-gateway
lwapp ap ip controller ip address
I add managment ip address as CISCO-LWAPP-CONTROLLER in my DNS server (dns server ip address
...and How the LAP will know the ip address of the dns server (to resolve the CISCO-LWAPP-CONTROLLER to ip address of the WLC)?
Scott Fella Thu, 06/26/2008 - 17:41
The ap will know of the DNS server from the DHCP Address.... if you were using DNS. Since you hard coded the AP, you don't need it now. Just like how users obtain an ip and know of thesir DNS servers.... same with the ap.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
