06-26-2008 08:54 AM - edited 02-21-2020 03:47 PM
Please attached picture because I hope that explains what I really want to do, but here is the break down.
When a Client VPN connects for remote access to 1-ASA5510 I want all Internet traffic to be sent to 2-ASA5510 instead of back out the default route. When it goes out 2-ASA5510 it crosses through out Content filter. 2-ASA5510 has Split Tunnel set up and we are trying to do away with SPlit Tunnel.
I hope this is clear enough.
Any ideas would be helpfull
Dan
Solved! Go to Solution.
06-27-2008 01:59 AM
Dan,
Tricky but do-able! Firstly there is a nice feature in the ASA that allows remote proxy configuration on a per VPN profile basis:-
group-policy <
msie-proxy method use-server
msie-proxy server value x.x.x.x
msie-proxy local-bypass enable
Yep you guessed it - only works on Microsoft Internet Explorer.
I don't think any policy based routing would work for you - bummer.
But you could try another feature - tunneled traffic, which is normaly used in the EasyVPN topllogy:-
ASA configuration right at the bottom, I would probably test this with the IP address of the 2651 router!
HTH.
06-27-2008 01:59 AM
Dan,
group-policy <
HTH.
06-27-2008 07:57 PM
try to make static route on the windows pc itself
with route add 0.0.0.0 0.0.0.0 defaultgateway
while it is not scaleable
