Association of DSPFARM
Jun 26th, 2008
I configured successfully meet-me service on CCME 4.1, but I have a doubt on the correct association of the profile for transcoding cause the status is ASSOCIATION IN PROGRESS, what could be missing??
2821#sh dspfarm all
Dspfarm Profile Configuration
Profile ID = 2, Service = TRANSCODING, Resource ID = 2
Profile Description :
Profile Admin State : UP
Profile Operation State : RESOURCE ALLOCATED
Application : SCCP Status : ASSOCIATION IN PROGRESS
Resource Provider : FLEX_DSPRM Status : UP
Number of Resource Configured : 2
Number of Resource Available : 2
Codec Configuration
Codec : g711ulaw, Maximum Packetization Period : 30
Codec : g711alaw, Maximum Packetization Period : 30
Codec : g729ar8, Maximum Packetization Period : 60
Codec : g729abr8, Maximum Packetization Period : 60
Profile ID = 1, Service = CONFERENCING, Resource ID = 1
Profile Operation State : ACTIVE
Application : SCCP Status : ASSOCIATED
Codec Configuration
Codec : g711ulaw, Maximum Packetization Period : 30 , Transcoder: Not Required
Codec : g711alaw, Maximum Packetization Period : 30 , Transcoder: Not Required
Codec : g729ar8, Maximum Packetization Period : 60 , Transcoder: Not Required
Codec : g729abr8, Maximum Packetization Period : 60 , Transcoder: Not Required
Codec : g729r8, Maximum Packetization Period : 60 , Transcoder: Not Required
Codec : g729br8, Maximum Packetization Period : 60 , Transcoder: Not Required
SLOT DSP VERSION STATUS CHNL USE TYPE RSC_ID BRIDGE_ID PKTS_TXED PKTS_RXED
0 1 9.4.5 UP N/A FREE xcode 2 - - -
0 5 9.4.5 UP N/A FREE xcode 2 - - -
0 6 1.1.137 UP N/A FREE conf 1 - - -
0 9 1.1.137 UP 1 USED conf 1 7798 32071 12709
0 9 1.1.137 UP 1 USED conf 1 7804 27321 27311
Total number of DSPFARM DSP channel(s) 4
Thanks for your help.
Juan Carlos
Chad Stachowicz Thu, 06/26/2008 - 10:07
  • Silver, 250 points or more
Juan,
sccp ccm group 22
bind interface GigabitEthernet0/0.30
associate ccm 7 priority 1
associate profile 1 register confdsp1
dspfarm profile 2 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
maximum sessions 2
associate application SCCP
dspfarm profile 1 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 2
conference-join custom-cptone jointone
conference-leave custom-cptone leavetone
I don't see that the transcoding profile has been associate at all!
HTH,
Chad
Juan Carlos Ari... Thu, 06/26/2008 - 10:31
Hi Chad,
That's exactly my problem and my doubt, could you kindly give your comments on how to associate transcoding profile.
I appreciate for your answer.
Juan Carlos
Juan Carlos Ari... Thu, 06/26/2008 - 10:39
I test it with this command and it's the same:
sccp ccm group 22
associate profile 2 register mtp001de5e1d5f8
Kindly please give me your comments.
Juan Carlos
Chad Stachowicz Thu, 06/26/2008 - 10:49
did you add mtp001de5e1d5f8 as a transcoding resource unfer CCM? Check registration status on the CCM and see if it shows registered then..
HTH,
Chad
Juan Carlos Ari... Thu, 06/26/2008 - 11:01
Well Chad, I just remember you that I'm running CCME, I will refresh my configuration only for the dsp if this could help to see the problem:
sccp local GigabitEthernet0/0.30
sccp ccm 172.16.0.1 identifier 7 version 4.1
sccp
sccp ccm group 22
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
maximum sessions 2
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 2
telephony-service
sdspfarm conference mute-on 845 mute-off 845
sdspfarm units 2
sdspfarm transcode sessions 2
sdspfarm tag 1 mtp0014f2018ad0
sdspfarm tag 2 confdsp1
conference hardware
Juan Carlos
Juan Carlos Ari... Thu, 06/26/2008 - 11:14
Chad, now I got it and both are associated, I had the ID tag interchanged on SCCP group and telephony-service, on this last post I realized that.
Thanks anyway for your time.
Juan Carlos
