Warning: Start and End addresses overlap with broadcast address.
Jun 26th, 2008
I've just reconfigured my pix 515e.
When I assign a global address, I get an error "Warning: Start and End addresses overlap with broadcast address."
Not sure what it means... Is it saying the address assigned to the WAN is a broadcast address for the network?
pix(config)# ip address outside 10.10.102.23 255.255.255.0
pix(config)# ip address inside 10.16.1.1 255.255.255.0
pix(config)# ip address dmz 10.31.1.1 255.255.255.0
pix(config)# global (outside) 1 interface
outside interface address added to PAT pool
And upon reload, I get this message, "Error: can not add name attributeType" Anyone know what this means?
Thanks.
Overall Rating: 3 (1 ratings)
dhananjoy chowdhury Fri, 06/27/2008 - 00:00
  • Silver, 250 points or more
could you post the config ( make sure you remove the sensitive info).
pixnewb11 Mon, 06/30/2008 - 09:47
Hello
PIX Version 6.1(4)
nameif ethernet0 outside security0
nameif ethernet1 inside security100
nameif ethernet2 dmz security40
enable password encrypted
passwd encrypted
hostname pix
domain-name domain.com
fixup protocol ftp 21
fixup protocol http 80
fixup protocol h323 1720
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol sip 5060
fixup protocol skinny 2000
names
access-list 101 permit tcp host 10.10.225.12 host 10.10.102.23 eq 443
access-list 102 permit ip 10.31.1.0 255.255.255.0 10.16.1.0 255.255.255.0
access-list 102 permit ip 10.31.1.0 255.255.255.0 any
pager lines 24
interface ethernet0 auto
interface ethernet1 auto
interface ethernet2 auto
mtu outside 1500
mtu inside 1500
mtu dmz 1500
ip audit info action alarm
ip audit attack action alarm
pdm history enable
arp timeout 14400
nat (inside) 1 10.16.1.0 255.255.255.0 0 0
nat (dmz) 1 10.31.1.0 255.255.255.0 0 0
static (inside,outside) tcp 10.10.102.23 443 10.16.1.23 443 netmask 255.255.255.255 0 0
access-group 101 in interface outside
access-group 102 in interface dmz
route outside 0.0.0.0 0.0.0.0 10.10.102.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h323 0:05:00 si
p 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
no sysopt route dnat
telnet timeout 5
ssh 10.10.102.223 255.255.255.255 outside
ssh 10.16.1.0 255.255.255.0 inside
ssh timeout 5
terminal width 80
Cryptochecksum:....
: end
[OK]
Fernando_Meza Mon, 06/30/2008 - 16:53
  • Gold, 750 points or more
Your config looks OK. I suspect the error might be a bug related whihc does not surprise me because you current OS level is very old. I suggest you upgrading to the latest 6.X version .. PIX OS version 6.3(5)
I hope it helps .. please rate helpful posts
