udld
Jun 26th, 2008
I have 3560 with 12.2.37 se1 connnected via
fiber to 3550 with 12.1.22.ea4
I am enabling udld aggressive
as soon as i enable this my fiber ports go into error disble
before I enable this everything looks good on the interface no errors
Anybody seen this issue
Overall Rating: 5 (1 ratings)
rpratapa Thu, 06/26/2008 - 11:18
You need to configure udld in aggressive mode on the other switch as well. In udld aggressive mode, the switch expects to receive a "valid reply message" ( sort of hello) from the other switch within a specific period of time. If this does not happen, the port id "disabled"
Hope this helps
-rk
jfeo Thu, 06/26/2008 - 11:22
thanks for the reply I do have it configurd on the other switch
but I still get the error disable
is there a way to adjust the time
jfeo Thu, 06/26/2008 - 11:31
No just on one usually the 3560
and when I do reset udld goes right back to error disable
what is the time limit
rpratapa Thu, 06/26/2008 - 11:37
It appears that 3560 is not receiving the "valid reply" from 3550 and that is the reason it's port is being "disabled".
Are the fiber strands OK? properly connected?
-rk
francisco_1 Thu, 06/26/2008 - 11:47
what udld aggressive mode does is, it will make eight attempts to re-establish the UDLD neighbor relation before error disabling the port if the 3560 is not receiving any responses from the 3550.
The last time this happened to me was a faulty sfp on my 3560.
Couple of things to check
Try replacing your fiber cable if that does not help try another port.
Also you might what to disable udld and enable udld debug event / packet before enabling udld again to see what the problem might be.
Good luck.
jfeo Thu, 06/26/2008 - 11:51
Thanks I replaced patch cables same thing
might be a bad gbic hope not
when I have a bad gbic I find symbols errors which I don't see
jfeo Thu, 06/26/2008 - 11:58
this is from debug
%UDLD-4-UDLD_PORT_DISABLED: UDLD disabled interface Gi0/2, unidirectional link detected
%PM-4-ERR_DISABLE: udld error detected on Gi0/2, putting Gi0/2 in err-disable state
%udld_linkchange called, reason = link, new_link_state = down, cookies = 1
%LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/2, changed state to down
%LINK-3-UPDOWN: Interface GigabitEthernet0/2, changed state to down
francisco_1 Thu, 06/26/2008 - 11:58
try to replace the gbic and see what happens...
also make sure both switches not negotiating speed. issue "speed nonegotiate"
jfeo Thu, 06/26/2008 - 12:13
wow thank you very much
speed nonegotiate worked
