RDBMS Synchronization Error with Action Code 123
Answered Question
Jun 26th, 2008
Hi there. I've been trying to create a .csv file to import into my secure acs 3.3. Most of the file works, except the lines with Action Code 123(ADD_DIAL_ACCESS_FILTER). The line looks like this.
20, 0, User-Name,,123,,"Site-Device,*,*,*",AAA Client/Port,,6/25/2008 9:46,0,,,0
After running the sync, i go into the rdbms report. When it gets to these lines in the csv file, i get the ERROR: Parse Error: Reason - Value out of Range" [SI=20 A=123 UN="User-Name" GN="" AI="" VN="" V1="Site-Device * * *" V2="AAA Client/Port" V3=""]
I've tried messing around with the VI section, but can't seem to get it right.
I have been able to use Action Code 122 for the ADD_NAS_ACCESS_FILTER. I want this user to only be able to access the devices in this section.
Please help.
Thank You,
Andrew S.
Correct Answer by darpotter about 8 years 11 months ago
V2 should have one of these literal values (without the quotes):
"CLID"
"DNIS"
"CLID/DNIS"
"NAS/PORT"
The value of V1 will should then match to be either a single clid or dnis value or combined clid/dnis or nas/port
eg "1.2.3.4/tty0" or "214-300-123/001800123456"
Although I wrote a lot rdbms sync... I dont think this bit was mine!!!
Overall Rating: 5 (2 ratings)
Correct Answer
darpotter Wed, 07/02/2008 - 06:53
  • Silver, 250 points or more
"CLID"
"DNIS"
"CLID/DNIS"
"NAS/PORT"
