Unity 5 move SQL database
Answered Question
Jun 26th, 2008
I have a unity 5 installation but the drive is running out of space. There is a spare drive with plenty of space. Exchange is sitting on the same drive that is running out of space (as is the CommServer folder).
Anyone know of a procedure for this.
Michael
Correct Answer by Chad Stachowicz about 9 years 4 weeks ago
Michael,
Check in the install guide it shows how to use OSQL step by step in order to move a database. This is a standard Procedure on any Unity installation with 8 drives!!
HTH, please rate helpful psots!
Chad
Overall Rating: 5 (1 ratings)
Correct Answer
Chad Stachowicz Thu, 06/26/2008 - 11:25
  • Silver, 250 points or more
Michael,
Chad
mlong0000 Thu, 06/26/2008 - 11:28
Hi Chad
thanks for the reply. What else could be moved to the new drive which could possibly fill up the original drive again.
Chad Stachowicz Thu, 06/26/2008 - 11:49
log files for SQL. How many drives do you have.. partitions? Also exchange tmp db can be moved..
HTH,
Chad
mlong0000 Thu, 06/26/2008 - 11:53
yeah Im wondering about logs I see in c:\program Files\Exchsrvr\MDBDATA
They are taking up about 2Gb
I have 2 partitions.
Chad Stachowicz Thu, 06/26/2008 - 12:17
generally I have sql and exchange + sql logs on one drive, and exchange db on the other.
Chad
