David Stanford Thu, 06/26/2008 - 12:37
Are you talking about adding the ssh/telnet credentials for a device or the transport protocol order? Or are you talking about the client LMS uses to telnet or ssh?
If you are talking about #1 this is done under CS Device Management.
#2 would be done under RME - Admin - Config Mgmt - Protocol
bmestep Mon, 06/30/2008 - 09:58
{you'll need this if you don't already have SSH working from the topology maps}
If you're talking about right-click SSH access from Topology views, you'll need to do do the following on the workstation displaying the map view:
- Go to Control Panel -> Java Plug-In
- On the Advanced tab set the Java Runtime parameters to:
-DCMSSH={path to your SSH Program}
* In my case it reads: -DCMSSH=C:\Progra~1\PuTTY\Putty.exe
- Once this is done, hit apply and close all Browser windows and any running Java applets.
- Fire up LMS and give it a try
This is also found under Using Topology Services in the Campus Manager documentation.
