Internet Access in MPLS VPN scenario
Jun 26th, 2008
  • Gold, 750 points or more
I do have topology CE8-PE2(AS 65001)-PE1(AS 65001)-ASBR1(AS1).
Now PE2 and PE1 both are in same AS and PE1 has ebgp with ASBR1, ASBR1 is my internet router.
I do have vrf ce on router PE2 and have attached that vrf on PE2 interface where CE8 is connected.
and all the config are in attachment.
regards
Devang
Overall Rating: 5 (1 ratings)
lee.reade Fri, 06/27/2008 - 02:57
  • Silver, 250 points or more
Some config is missing from the BGP vrf, you have not generated the VPNV4 routes for the vrf, please add on PE2;
router bg 65001
address-family ipv4 vrf ce
red connected
red static
can you post ;
show ip route
show ip bgp
From the PE1 & PE2?
+ show ip bg vpn all from PE2 only
LR
devang_etcom Sat, 06/28/2008 - 16:50
Thanks for hint... yes its done now...
regards
Devang Patel
