Upgrade from 6.X to 7.X script
Jun 26th, 2008
I am working on an upgrade script to take my PIX 515E from a restricted license 6.35 to an unrestricted 7.24. This is a mission critical piece of equpment so I want to make sure I am doing it right.
Below is what I have from a 30,000 ft level came up with. Does it make sense?
Phase 1 (upgrade to 7.X)
1. Backup configuation to tftp
2. Power down unit
3. Install memory and vpn card from PIX kit
4. Power up and test memory upgrade
5. Upgrade PIX to 7.24 using monitor mode
6. Reboot
7. Test
Phase 2 (upgrade license to unlimited)
TBD
Overall Rating: 5 (2 ratings)
davistw Fri, 06/27/2008 - 06:19
Thanks. I have already checked and my config does not have any issues.. So I should be good to go...
davistw Fri, 06/27/2008 - 09:50
I think I left out one other step...
0. Check config for problems (conduit etc)
2. Power down unit
6. Reboot
6.1 Upgrade PIX to ADSM 5.24
7. Test
JORGE RODRIGUEZ Fri, 06/27/2008 - 11:08
the script process looks good, I would just in case save your running activation key from previous version to keep it in your records, just save the output of show version under code 6.x.
Rgds
-Jorge
