vtp version
Answered Question
Jun 26th, 2008
  • Bronze, 100 points or more
hi every body1
can any body help with the following questions:
1) when we enable vtp, which version is used by default?
2) what happens if we enable vtp version 2 on one vtp server switch in a domain
all the other but one support version 2?
will the version 1 be used because one switch does not support version 2?
3) Assume vtp pruning is enabled
let say we have a switch with following active vlans . vlan1,2,3,4
if i configure the command :
switchport trunk pruning vlan 4
Will this command cause switch not to include vlan 4 in vtp joint message though vlan 4 is active in the switch ?
thanks alot !
Correct Answer by Pravin Phadte about 8 years 10 months ago
1) When VTP is enabled its VTP verison-1 These days it may depend on ios also
2)When you enable VTP version 2 on a switch, all of the version 2-capable switches in the domain enable VTP version 2.
Also A VTP version 2-capable switch can operate in the same VTP domain as a switch running VTP version 1 if VTP version 2 is disabled on the VTP version 2-capable switch (VTP version 2 is disabled by default).
3) Yes Vlan 4 will not be included in vtp joint message.
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/catos/8.x/configuration/guide/vtp.html#wp1021050
Hope this helps,
Pravin
Correct Answer by babatunde_sanda about 8 years 10 months ago
By defualt VTP 1 is enable. enabling vtp 2 on the server switch when others don't support version 2 will cause a replication problem (VLAN database replication). By enabling prunning (ideally on the server switch) vlan 4 which you prunned will not be carried on the trunk link. Prunning is basically used to let the switch know it shouldn't carry vtp information for vlan 4 across the link you configure it on.
(If this helps please rate. Thank you.)
Overall Rating: 5 (3 ratings)
alanyang1 Thu, 06/26/2008 - 14:56
you can find out the vtp version by typing "show vtp status".
Correct Answer
babatunde_sanda Thu, 06/26/2008 - 15:56
wizassonic Fri, 06/27/2008 - 00:04
Hi there,
You could enable vtp prunning ONLY on the server. On the client the Switch rejects the command.
What I don't understand about the default version is that there is something unclear in the output of sh vtp status
On the top there is VTP version 2 and on the bottom
VTP V2 Mode : Disabled
How is this possible?
Thanks.
Switch# show vtp status
VTP Version : 2
Configuration Revision : 247
Maximum VLANs supported locally : 1005
Number of existing VLANs : 33
VTP Operating Mode : Client
VTP Domain Name : Lab_Network
VTP Pruning Mode : Enabled
VTP Traps Generation : Disabled
MD5 digest : 0x45 0x52 0xB6 0xFD 0x63 0xC8 0x49 0x80
Configuration last modified by 0.0.0.0 at 8-12-99 15:04:49
Correct Answer
Pravin Phadte Fri, 06/27/2008 - 01:11
  • Silver, 250 points or more
Hope this helps,
Pravin
sarahr202 Fri, 06/27/2008 - 06:29
thanks for all of you who replied. Mr wizasonic raised a very good point that i intented to post regarding " show vtp status".
Does any one have clue about what mr wizassonic asked?
thanks alot !
babatunde_sanda Fri, 06/27/2008 - 16:45
In the sh vtp stat command output the initial vtp version shows that the switch can support version two and below since it shows disabled, it means the version being used on the network is version 1.
(if this helps please rate)
wizassonic Sat, 06/28/2008 - 03:14
Just to make my question clear: It is said that the default version of VTP is 1.
Here is the output from show vtp status from a default configuration switch:
Look at the 1st and 8th line of the output. The first line says VTP VERSION 2 and the 8th line says: VTP V2 Mode : Disabled
VTP Version : 2
