Joe Clarke Thu, 06/26/2008 - 16:22
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
There doesn't appear any errors here which leads me to believe the VM is dying. There should be some hs_* files lying around NMSROOT\MDC. Please post the most recent.
Joe Clarke Fri, 06/27/2008 - 12:18
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
It looks like your NMSROOT\MDC\etc\regdaemon.xml file has either become corrupt, zero bytes, or casuser no longer has permission to read this file. If the permissions are correct, then you will either need to restore a known good backup, or reinstall LMS from scratch.
js88888888 Fri, 06/27/2008 - 14:57
Thanks, that did it. I restored that xml file and its working.
