enable jumbo frame on Catalyst 6513
Jun 26th, 2008
  • Silver, 250 points or more
Hi all,
If I have Ether-channel on the Catalyst 6513 and that I want to enable jumbo frame
on the ports that are belong to the
Ether- channel port-channel. Do I need to enable jumbo frame on the physical
ports itself or just the port-channel?
According to Cisco, I only need to do it
on the port-channel, is that correct?
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.1E/native/configuration/guide/sw_int.html#wp1053326
