1131 IOS upgrade to LWAPP fails
Jun 26th, 2008
Has anyone seen this before or know of a workaround. The 1131 is operating with IOS version 12.4(10b)JA3. We tried to perform this upgrade using two different laptops, but received the same message “Unable to get root certificate status”… we received this same message when trying to migrate a different 1131 that is operating with the same IOS version.
2008/06/26 17:54:18 INFO Created RSA Keys successfully
2008/06/26 17:54:18 DEBUG Generating Public Key
2008/06/26 17:55:03 DEBUG Generating SSC Certificate
2008/06/26 17:56:05 INFO SSC Generated Successfully
2008/06/26 17:56:05 DEBUG Saving the SSC Configuration
2008/06/26 17:56:36 INFO Saving SSC Certificate
2008/06/26 17:56:36 DEBUG Generating Root Certificate
2008/06/26 17:56:36 DEBUG Check whether Root Certificate is already present or not
2008/06/26 17:57:27 ERROR Unable to Get Root Certificate Status
Overall Rating: 5 (1 ratings)
dennischolmes Mon, 08/11/2008 - 05:34
Sounds like corrupted original version of autonomous code Scott. I would downgrade the code back to autonomous which should give a good image back to the AP then try the upgrade again. If that fails, I'd check to make sure the image I'mm using for upgrade hasn't got corrupted. I'd also download another copy of the tool if you're using the stand alone version. If all those fail it could be bad memory on the AP.
Scott Fella Mon, 08/11/2008 - 06:22
Thanks.... What fixed it was that we had to strip out alot of the configuration to bare basics. Seemed like the upgrade works better that way instead of trying to upgrade AP's with full configurations.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
