UC520 7931 Question
Paolo Bevilacqua Fri, 06/27/2008 - 02:59
Hi, the GUI has many bugs like that. Either try upgrading GUI files, or use the CLI.
Paolo Bevilacqua Fri, 06/27/2008 - 05:00
Do you have the files from UC520 4.2(7) zipfile ?
If so you should ask the TAC, because there is nothing you can do when the GUI misbehaves, beside using the CLI.
Paolo Bevilacqua Fri, 06/27/2008 - 05:10
Have you configured type 7931 under each ephone ?
That would be only prerequiste and if still GUI problems you should deal with cisco to fix them.
As an appreciation to those providing answers, please rate useful posts!
